Driveshaft decision to make
RE: Driveshaft decision to make
ORIGINAL: 06GT4RAD
Ron which driveshaft loops do you suggest? I have a CHE Front loop but what about the rear?
Richard
ORIGINAL: spyder7724
mine has been proven to hold up behind 500+rwhp manual trans drag cars with slicks launching at 5000rpms + If you have more than 700hp and plan on drag racing(hard launches) then you really need to upgrade the transmission to something stronger which then will require a different driveshaft (with an older style slip-yoke instead of the slip-joint).
Mine use the same type materials that others claim will withstand 900hp+.
6061 T6 aluminum tubing .110" thick and spicer 13 series ujoints.
they will withstand more than the rest of the stock drivetrain.
I always recommend the use of front and rear saftey loops mainly because they are required by NHRA and because our fuel tank surrounds the driveshaft which may cause a slight problem if you did experience a failure.
Richard
Galactic
04-29-2019 02:56 PM
Luke9222
10-22-2015 11:55 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
