Torque Converter Question
Old Aug 9, 2007 | 10:01 PM
spyder7724's Avatar
spyder7724
Default RE: Torque Converter Question
thats exactly what i did. I've worked with TCI on other race cars so I truct they would point me in the right direction. Most of the failures are from the lockup clutches. Guys tend to get aggressive with the lockup schedules...guilty also...and that leads to a short life for them. also they usually can't handle more than 200-300ft.lbs. so bringing in the lockup too soon will surely fry them quickly especially with any type of power adder making loads of torque. If you are planing on going the high HP route then you will be money ahead by using a PI multi disc converter or something of that sorts(especially if you are going to be aggressive with lockups and race the thing a bunch.
also contact doug at b.a.m.a.c.h.i.p.s. he will give you a tune that will make your car scream with that new converter.
Old Aug 10, 2007 | 03:54 PM
The Ghost's Avatar
The Ghost
And another twist. I changed my lock-up schedule with the stock unit. I can nose stand at around 3400rpm now with the stock unit. However it absolutley does not hit as hard as a converter designed to stall at 3400RPM and I got enough slipping durring normal driving to worry me. So I now only use the higher RPM lock-up when racing due to after launch I am above the lock-up RPM for the rest of the run.
Old Aug 14, 2007 | 05:57 PM
elevsec50's Avatar
elevsec50
Hello every one. i am new to this site i have a 06 gt auto and stumbled across this site.i am putting in a tci 3000 stall right now as we speak.i see you talking about changing lock up timing as well as shift points(COOL) how is this done? i assume you need a programer of sorts, witch one sct or diablo,also any other good performance mods for a some what daily driver would be helpfull, thanks in advance.
Old Aug 14, 2007 | 06:33 PM
Heavyg72's Avatar
Heavyg72
I just had the TCI 3000 stall installed today and wow what a difference. From 3000 on it just pulls like crazy. I highly recommend this mod to anyone with the auto tranny. My only regret is not doing this before the SC was installed. From a 20-30 roll it just goes nuts so I guess suspension and tires are next for me. I did go with the TCI so I will post if I run into any issues but right now I really like it. Thanks!
Old Aug 14, 2007 | 06:35 PM
cheftjpeck's Avatar
cheftjpeck
ORIGINAL: Heavyg72
congrats...yeah I am going back and forth...originally I had a great deal on a PI single disk...but the seller had a family emergency and had to back out of the deal...would have only cost me $499.....but now back in the research market for one...still going to probably go with a PI....but have to wait on the dough ......
Old Aug 14, 2007 | 08:18 PM
MexGT's Avatar
MexGT
K i'm a noob in the TC business thing, but its definetelly something i'll buy in the near future, hopefully within the next months, whats the difference bewteen ordering a single disk or multi-disk TC? Planing on a PI @3,500 ...
Old Aug 14, 2007 | 08:20 PM
cheftjpeck's Avatar
cheftjpeck
ORIGINAL: MexGT
multi disk is reccommended for cars that are supercharged and people who like to do aggressive lockups on their TC. mainly for the drag strip..
Old Aug 14, 2007 | 08:36 PM
MexGT's Avatar
MexGT
and will work also for street use? goin to the strip every now and then ...
Old Aug 16, 2007 | 09:37 PM
SpeedRacer9220's Avatar
SpeedRacer9220
I am also thinking of going this route soon.Do you need a re-tune to run the converter? I am using a B A M A tune right now and will the car still run good with out a special tune for the converter?
Old Aug 17, 2007 | 08:01 AM
Heavyg72's Avatar
Heavyg72
SpeedRacer9220 - I had the same question so I asked Brent at Brenspeed and no I did not have to retune after the TC was installed.
