CAMS
Old Dec 8, 2007 | 11:40 AM
  #31
UrS4's Avatar
UrS4
Default RE: CAMS
That's cool, what whp is he putting down?
Old Dec 8, 2007 | 01:08 PM
  #32
06Saleen3V's Avatar
06Saleen3V
Default RE: CAMS
ORIGINAL: UrS4
So is it reasonable to expect 400whp NA with the following?
1) Stroker kit to 298ci
2) Heads
3) Cams
4) LTs and O/R pipe
5) UDPs
6) Delete plates
7) CAI and tune
If you use the BBR stage II cams, I would say you would be nudging 400rwhp
Old Dec 8, 2007 | 01:21 PM
  #33
phatphil's Avatar
phatphil
Default RE: CAMS
Brenspeed is offering a new set of cams which are labeled NSR no springs required, this makes the installation easier. I believe his site has the details on h.p. gains and install price. I think it is under the tech section, cams and install for under 1000.00. His site also says they're developing a set of cams for the Saleen S/C, should be interesting. NSR means he will use your existings springs.
Old Dec 8, 2007 | 05:23 PM
  #34
UrS4's Avatar
UrS4
Default RE: CAMS
So around 400 whp on a NA car.
Obviously it would cost more than slapping on a twin screw but . . .
Keeping it NA might be the way to go for the road racer. It will be 100+ lbs lighter and not suffer from heat soak and not strain the internals as much.
Old Dec 8, 2007 | 06:34 PM
  #35
MusiccityGT's Avatar
MusiccityGT
Default RE: CAMS
ORIGINAL: UrS4
I did a set of Comp stage 3's for a guy running an 05 in the American Iron series. He had to detune to 325 h/p to keep it within the rules for the class. Powerwise other than the cams, he had a CAI, Long tubes, UDP's and 4:56 gears.
Old Dec 10, 2007 | 07:53 AM
  #36
tonkpils555666sas's Avatar
tonkpils555666sas
Default RE: CAMS
If we did buy heads for our cars, is it worth it? or would you get similar gains by reporting and polishing the stock heads...?
Old Dec 10, 2007 | 12:59 PM
  #37
BFMacias's Avatar
BFMacias
Default RE: CAMS
How much better are the BBR cams compared to Crower stage II's? They seem to have the same durations and lift measurements. Am I completely wrong or what?
Old Dec 10, 2007 | 01:01 PM
  #38
sleeper2's Avatar
sleeper2
Default RE: CAMS
I am glad the n/a mods are starting to be explored. I am aware of the advantages (and great track record) of forced-induction on these cars, but something still appeals to me about building a 298 and staying n/a. I must be nuts!
Sleeper2
Old Dec 10, 2007 | 01:04 PM
  #39
Texotic's Avatar
Texotic
Default RE: CAMS
me too, i think i'd be happier staying N/A...
GimpyHSHS
19
Dec 19, 2023 01:12 PM
patchshaffer
Tuner Central
Oct 5, 2015 02:24 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
junior04
Sep 28, 2015 10:53 AM
Ryan Fitzpatrick
Sep 14, 2015 02:21 AM
