NITROUS
Old Dec 10, 2007 | 05:07 PM
Va. Stang's Avatar
Va. Stang
Default RE: NITROUS
Anyone know what guages would be best to run with a 125 hp wet nitrous kit?
Old Dec 10, 2007 | 05:09 PM
androdz's Avatar
androdz
I ♥ Acer
Default RE: NITROUS
Wideband is the only real gauge you need. BTW you can get my kit it is brand new in box.
Andrew
Old Dec 10, 2007 | 07:10 PM
D_Gusler's Avatar
D_Gusler
Default RE: NITROUS
ORIGINAL: white07
ORIGINAL: D_Gusler
ORIGINAL: MusiccityGT
Agreed, and as I said in the first post, you are getting CLOSE to starving the fuel railat a 125 shot. It also depends on the kit and the jetting. Some measure Fly/W and some R/W ratings. I am running a 100 shot Ny-Trex system andI am on the edge of fuel demand ability. Brenspeed will not do an e-tune for anything over 100 shot because of this reason. Iput mine on the dyno to be sure it was spot on. I have a fuel pressure switch that will kill the system if the fuel pressue drops below 38psi and I also run a wideband guage in my pillar pod so I am aware of the A/F at all times.
Uhhhhh, I hate to say it, but Brenspeed does tune for 125 &150 shots---wanna ask how I know[8D]
Anyways, to the OP. I have a kit you need if you are interested in. Lots of upgrades & extras--just follow the link in my sig.
Colder plugs & tuning are necessary for 100shot +
Plus you'll start wanting to look at better tires
IM all over that shyt.
Sounds good man.I loved it, just wanted something to run all the time. Although the purge is a very intimidating factor.
As for guages I would reccomend three to be very safe---fuel pressure, wideband air/fuel, nitrous pressure. Of the three, nitrous bottle pressure is probably the most important. Without good bottle pressure you can get into all kind of issues.
Old Dec 10, 2007 | 08:21 PM
MusiccityGT's Avatar
MusiccityGT
Default RE: NITROUS
ORIGINAL: D_Gusler
Ok, I knew should have made that statement more clear, knowing I would be called on that. When I talked to Dave he said they will not do an e-tune for anything over 100 shot UNLESS you have any upgraded fuel system, plugs etc. I have one of their nitrous tunes, but am currently running a RWTD custum tune, who does all my dynotuning. Oh, and in addition to the other items mentioned, a window switch is a real good idea as well.
Old Dec 10, 2007 | 10:12 PM
D_Gusler's Avatar
D_Gusler
Default RE: NITROUS
ORIGINAL: D_Gusler
Yeah, I got ya now. I agree on the windowswitch--for these cars, I would recommend the Zex traction control box tho--You can select everything as far as timing wise--gear you spray & the rpm range(3000-6100rpm for example).
Old Dec 10, 2007 | 11:18 PM
Mishri's Avatar
Mishri
Mish-ogynist
Default RE: NITROUS
hmm so will brenspeed do a 150 tune if you bring it to them? because they have a video of a 150 shot stang w/o any mention of fuel system upgrades.. just the kooks exaust, macmufflers,C&L intake, pulleys, 3.73, comp cams.. wondering if you got the same exact setup if he would do it?
Old Dec 11, 2007 | 10:39 AM
probinator's Avatar
probinator
Default RE: NITROUS
With a 100 shot I ran a 89 tune minus *2 timing on 91 gas and HTO plugs
Now I'm on the 125 shot with 87 tune and minus *4 timing. With HTO plugs
If you have a 150 shot I guess you could do a few glory runs but I would take out more timing, and then upgrade to a boost a pump.
I want to get it on the dyno and play around with the jets...
Old Dec 11, 2007 | 11:34 AM
white07's Avatar
white07
Default RE: NITROUS
ORIGINAL: D_Gusler
ORIGINAL: white07
ORIGINAL: D_Gusler
Nice. Yeah I was for sure gonna get a bottle pressure and wideband. Ill probably purge it more than ill use it but atleast ill have it just in case.
Old Dec 11, 2007 | 02:49 PM
androdz's Avatar
androdz
I ♥ Acer
Default RE: NITROUS
I ran 150 for around 6 months. The only real gauge you need is the wide band the bottle pressure the zex automatically removes gas. to make up for the less pressure. Engine going rich = nothing ( what happens when you have low bottle pressure) Engine going lean with nitrous and no wideband to check for it = blown engine. I did get the boost a pump to be safe but I would recommend getting the gt500 pumps instead.
Andrew
Sandmanbjj
Aug 21, 2015 12:38 PM
mstngdvr17
Dec 25, 2003 04:55 PM
jhogan2424
Nov 5, 2003 08:51 PM
67gt500
Aug 17, 2003 04:01 AM
