What's my hp?
Old 12-29-2007, 11:43 PM
doahdogg
doahdogg's Avatar
Default What's my hp?
Ok, I just bought my first car recently. 2005 mustang gt. I'm trying to make it fast enough to keep up w/ my buddies 06 gto 400. I have flowmaster mufflers, x pipes and a new K & N cold air intake. What should my hp be at? I raced an 06 gto the other day twice and beat him both times. I think he must have been a horrible shifter. Also, what should I but next to increase my hp? thanx for the help.
doahdogg is offline
Old 12-29-2007, 11:57 PM
mygt500
Multi-Tasking Moderator!
mygt500's Avatar
Default RE: What's my hp?
Maybe 270-290 to the rear wheels with a canned tune for the K&N (depending on which CAI you have- mine at the time did not require a tune (K&N) and after the tune I could feel the power increase). Its not just HP that wins races!!!!!!!!! Welcome to the forum! J
mygt500 is offline
Old 12-30-2007, 12:04 AM
doahdogg
doahdogg's Avatar
thanx for the help bro! Glad to be here.
doahdogg is offline
Old 12-30-2007, 12:57 AM
Diabolical!
Diabolical!'s Avatar
ORIGINAL: doahdogg
Are you tuned? If not, your HP is probably pretty close to stock. Yeah, the GTO must have had a pretty crappy driver, because he should have killed you. Regardless, nice kill.
Diabolical! is offline
Old 12-30-2007, 01:49 PM
SilversurferV6
SilversurferV6's Avatar
if ur tuned and the gto is stock u shuld not have been killed u should have won as u claimed u did.
SilversurferV6 is offline
Old 12-30-2007, 02:57 PM
Argonaut
Argonaut's Avatar
Other things you can do to increase HP: the list is long. At the top in terms of both $ and HP are the obvious - supercharge, turbo or nitrous and/or built engines.
The cheaper bolt on mods produce much more modest gains:
- CAI (you already have)
- Custom Tune (not clear if you have)
- Long tube headers (decent gain)or shortys (small gain)
- UDPs (reduce parasitic losses)
- Aluminum driveshaft (reduce parasitic losses)
You can also go on a diet, starting with lighter weight wheels.
You can also transfer power you have to the ground more effectively with certain suspension pieces and bigger tires.
Lots of options....and $. Welcome to the world of modding.
Argonaut is offline
Old 12-30-2007, 09:17 PM
GT Rick
GT Rick's Avatar
Silversurfer is correct, A stock GTO should/will lose to a tuned stang....I have read that a stock stang would even beat the stock GTO.
Have fun adding mods. Something else to consider would be gears. That will really make the car hop!
GT Rick is offline
Old 12-30-2007, 09:25 PM
onederful100
onederful100's Avatar
stock vs stock the GTO will win in the 1/4 mile. its got 100 more hp. the stang may be able to keep up at low end but up top is where those GTO's, LS1's start pulling away. the stang may be better off the line, but those LS1's just walk around us, stock that is.
onederful100 is offline
Old 12-30-2007, 10:09 PM
memphis90
memphis90's Avatar
Easy way to increase accelleration, change rear gears.
memphis90 is offline
Old 12-30-2007, 11:14 PM
doahdogg
doahdogg's Avatar
thanx for all the feedback. very helpful!
doahdogg is offline
