Next mod for Auto?...
Old Jan 24, 2008 | 01:19 PM
zkiller's Avatar
zkiller
Default RE: Next mod for Auto?...
That depends what kind you buy and who does the install.
Cheap aftermarket converter like a TCI is about 550
A good one like a PI multi disk might be 800-1200 depending on who makes it and if it is a custom one.
Install requires removal of the transmission so 400-800 dollars depending on who does it and their shop rate.
Old Jan 25, 2008 | 04:25 PM
Newbreedgt05's Avatar
Newbreedgt05
I'd go with the 3.73's. They're not too expensive to install even though I did my own. They're a huge noticable difference over the stock 3.31's.
Old Jan 25, 2008 | 05:12 PM
zkiller's Avatar
zkiller
The TC will give you more seat of the pants feel and reduce your ET by more time.
Old Jan 26, 2008 | 09:00 AM
black S197's Avatar
black S197
Hm. I like my 4.30's.
Old Jan 26, 2008 | 05:07 PM
Heavyg72's Avatar
Heavyg72
I was just reading through the latest issue of MM&FF and they had a write-up on installing a new TCI Super Streetfighters in JDM's stroker car. The results were pretty impressive. Here are the end results in case you don't have it available:
60' - 1.71 to 1.58
1/4 - 11.87 to 11.64
I've done both mods with gears being the first. If I had to do it all over again I'd do the TC first and then gears as I noticed the most difference with the TC. Good luck and notice us know which route you take first.
Old Jan 26, 2008 | 08:59 PM
SD05GT's Avatar
SD05GT
Converter
Old Jan 26, 2008 | 10:58 PM
ShadyNinja's Avatar
ShadyNinja
nitrous 125 shot
Old Jan 27, 2008 | 12:50 AM
TopNotch06GT's Avatar
TopNotch06GT
i would go with a torque converter it makes you shift harder and can improve your 60 ft. times
[/align]
Old Jan 27, 2008 | 12:43 PM
rshamekh's Avatar
rshamekh
How bad is the TCI Street Fighter compared to the PI?
Old Jan 27, 2008 | 04:35 PM
Heavyg72's Avatar
Heavyg72
I wouldn't say TCI is bad but the PI is supposed to be a bit more heavy duty and handle more power. Which it should as it's twice the cost of the TCI. I spoke to the guys at JPC racing (where I bought mine and had it installed) and they haven't had any problems with them and Brent at Brenspeed is now selling them. I personally have not had any issues with mine either.
