rwhp rating for stock differential ?
#22
RE: rwhp rating for stock differential ?
ORIGINAL: Vapour Trails
How come people always rate equipment based on hp when it is only a measure of work. Torque is a measure of force.
1000 hp geared 1:1 at the axle wouldgive ballistic top speed, but couldnt twist an axle off.
I still think tires #1 in saying what it can handle, as they are the primary torque peak limiter. if you could put 5.13 gearsand topfueler slicks on a stock mustang, bet the stock engine would easily break the axle first time the clutch is dumped at 5k- yet itsstill only 300 hp.
a 500 hp @10,000 rpm turbine wont hurt the axle or spin the tires, yet a 250 hp @ 2500 rpmbigblockwouldeasily do one or the other...
torque peaks break stuff, twice the hp at twice the rpm= same torque...
#23
ORIGINAL: 06VistaBlueGT
I don't know about the diff but the axles on the 05's and up are 31 spline, previous years used 28 spline. It's going to take a lot to break these axles.
So the Tru trac is the best for a DD?
09-17-2015 07:32 PM
09-16-2015 07:53 PM
