HELP I cant get my crank pully of my 08 gt!
Im currently installing my steeda udp and I cant get the crank pully off. I have removed the bolt and washer and placed the 3 prong pully puller on and cranked on that with all my might! The only thing I can think of is maybe another washer??? Also in my frustration in giving up defeat and get a real mechanic to do itI stripped the treads of my crank bolt. So my plan is as follows get a new bolt from ford tomorrow and chase the treads with a tap and a oil change. Ok so questions are
1 how the F#&K do I get that pully off.
2 will chaseing the treads and flushing the oil get rid of the debris and possible shavings
3 in my cranking on the breaker bar i think i rotated the crank without the belt in place, will that affect the timming of the motor in anyway?
4 how bad did I really mess this up?
any and all assistance is much appreciated
Mike
Mike
RE: HELP I cant get my crank pully of my 08 gt!
its a real pain in the butt. i had to getboth 3 prong pullers and use the center of the big one and the shorter arms of the small one. then wedge a socket in between the puller bolt and the center part of pulley. also wedge a large screw driver on the frame below and into the center arm of the pulley to keep it from turning. then crank away. its tough but it worked for me. i turned my crank several times and it did not mess my timing up. ford dealership here wanted $360 to change it. my way didnt cost me very little. give it a shot. good luck.
Thanks for your repiles.
I got it off and changed the pullys, a hammer and some determination let it go. OMG the biggest pain in my *** finaly done!!!! good payoff though. lol
jessicarabbit
09-25-2015 12:41 PM
