question... CEL
Old Aug 28, 2008 | 10:51 PM
cj05roush's Avatar
cj05roush
Default question... CEL
hey guys. i just got a 05 roush mustang a few weeks ago. when i smash on it and run thru the gears ill drop it in 4th my CEL flashes and the engine seems to sputter just a bit. im not sure what is causing this. it doesnt happen till the 3-4 pull, the first few are great with no issues. the CEL just flashes and goes away. the car has plenty of power and nothing seems to be wrong at all except a slight sputter and then it goes away. anybody experienced this or anybody know what this could be?? thanks
Old Aug 28, 2008 | 10:56 PM
jwog666's Avatar
jwog666
if the cel flashes you have a misfire, get it scanned and find out which cylinder is missing. its most likely a coil going bad
Old Aug 29, 2008 | 12:02 AM
cj05roush's Avatar
cj05roush
hm... i was planning on replacing the plugs/wires shortly. should i just do the coils as well? where would be a good place to take it to get scanned? the dealership?
Old Aug 29, 2008 | 09:53 AM
abrush's Avatar
abrush
The V8 mustangs don't have plug wires. Instead they have COP's. (Coil on plugs) Your problem could be a bad plug or coil. I would run codes and see if anything comes up.
To answer your question, yes you can take it to the dealer but I believe they charge $60-$100 just to scan your car. I know Autozone will scan your car for free but I don't know how good their scanners are. Another option would be to buy a hand held tuner. They will check codes as well. If you ever plan on changing your air intake the tuner will be needed with most anyways. You can also purchase custom tunes from shops like Brenspeed or Bama to use with the tuner.
Old Aug 29, 2008 | 09:57 AM
acascianelli's Avatar
acascianelli
Goto Autozone/Murrays and use a scanner to pull and clear the code. Look up the code on the internet or post it here.
Old Aug 29, 2008 | 11:20 AM
cj05roush's Avatar
cj05roush
i was wondering about the wires, i never saw any. sorry im new to mustangs. i just bought a cai and sct x3. actually installed it 2 days ago. the CEL just flashes it does not stay on, will the tuner still read it? any specific brand of plugs and COP's you recommend?
Old Aug 29, 2008 | 05:35 PM
jwog666's Avatar
jwog666
the dealer scan tool is much better than the auto zone code puller. with the dealer scan tool they can look at data and tell you for sure if the coil is failing by performing a coil stress test. but if you have az scan it just replace the cop for the misfiring cylinder. no need to replace 7 good cop's. they are not cheap.
bryan616fl
Jan 25, 2019 09:07 PM
Urambo Tauro
Jun 10, 2016 03:28 AM
Scottyboy187
SVT Forums
Nov 20, 2015 02:57 PM
Scottyboy187
Nov 5, 2015 04:18 PM
BlackShelbyGt500
Aug 10, 2015 11:50 AM
