Electric Problems
Old Dec 10, 2008 | 01:57 PM
FIRE's Avatar
FIRE
Question Electric Problems
I have an 05 GT with 57,000 miles and I'm experiencing my first malfuntion; The engine cranks slow on start up when cold as if the battery is going. Don't know if this is the case or if starter is drawing too much power. Anyone else see this? Thanks!
Old Dec 10, 2008 | 02:01 PM
howarmat's Avatar
howarmat
s197 Junkie
well have you checked the battery to see if it is in proper working order?
Old Dec 10, 2008 | 02:22 PM
Nuke's Avatar
Nuke
An old battery in cold weather, even one that cranks fine in warm weather, will have a bit of difficulty cranking an engine. You should be able to have a capacity test done on the battery or simply get a new one if yours is the original. Although some batteries can last a long time, 3-4 years is about average with many batteries not making it much more than 3.
The battery in one of my SUV's is going on 9 years. I haven't replaced it just to see WHEN it'll actually die (but I DO carry jumper cables!).
Old Dec 10, 2008 | 07:07 PM
charliebrown266's Avatar
charliebrown266
Have the battery tested and check the cables.
Old Dec 11, 2008 | 09:38 AM
ski's Avatar
ski
Good stuff. Also, check the battery terminals for corrosion, and clean them if necessary.
Old Dec 11, 2008 | 02:09 PM
FIRE's Avatar
FIRE
Thanks. I've checked into it enough to be pretty sure it's the battery. I was just wondering if anyone had experienced starter and/or related electrical problems. This is the first model year after all and we've all been pretty lucky no gremlins have popped up that would be straightened out on later productions.
jma2
Jul 10, 2023 01:00 AM
ak98
Feb 18, 2023 08:36 AM
uberstang1
Sep 20, 2015 06:42 PM
ccdguy
Sep 19, 2015 05:20 PM
TfcCDR
Sep 14, 2015 12:08 PM
