Delayed throttle response.
Old Feb 6, 2009 | 10:15 PM
gman73's Avatar
gman73
Default Delayed throttle response.
Today I was driving about 75-80 and when I downshifted to 4th to accelerate, the car hesitated for a second and then took off. It also did it when I went from 5th to 3rd. It only happened twice and after that when I downshifted, the car accelerated normally. I was not driving that long of a distance or at a constant speed when I the delay happened, so I don't think it was one of the TSBs. Does anyone know what the delay could have been?
Old Feb 6, 2009 | 11:05 PM
Nuke's Avatar
Nuke
Although there's a TSB out there for the fuel pump, mine does it on rare occasions and I suspect it's the Traction Control System. Others have said that my symptoms and the one you describe aren't fuel pump related. Mine hasn't done it when I've had the TCS off. A few months back I had the TCS on, mashed it and it hesitated. At the same time I saw the TCS symbol on the speedometer light up.
Old Feb 7, 2009 | 12:02 AM
gman73's Avatar
gman73
I had the t/c off. It may have been a little water in the gas.
Old Feb 10, 2009 | 08:39 PM
Lifter583's Avatar
Lifter583
Try running some Techron in the next fillup, clean the MAF, and throttle body.
Old Feb 10, 2009 | 09:30 PM
Nuke's Avatar
Nuke
There's also 2 other theories that seem to arise in these discussions.
  1. the Fuel Pump TSB which is aimed at '05's and '06's but some '07 owners claimed the TSB "fix" worked for them; others not
  2. the drive-by-wire system is prone to "delays"
And another one that came to mind is throttle lag which is fixed with a custom tune. But a lot of people reporrting the problem HAVE custom tunes.
It's one of life's little mysteries...
Old Feb 14, 2009 | 12:10 AM
gman73's Avatar
gman73
Problem solved! Cleaned the TB and that made a difference in sound and performance. Even at idle my RPMS tend to stay a little higher. As far as sound, one of my co-workers said my car sounds meaner now.
Old Feb 14, 2009 | 12:43 AM
Redfire66's Avatar
Redfire66
gman,
what did you use to clean it?
Old Feb 14, 2009 | 01:01 AM
gman73's Avatar
gman73
Valvoline carb and choke cleaner.
rgingo
Forum Issues and Feedback
Oct 21, 2015 12:49 PM
UrS4
Oct 3, 2015 06:23 AM
guitarman376
Sep 30, 2015 05:54 PM
JDWalton
Sep 24, 2015 08:47 PM
94stangnewbe
V6 General Discussion
Sep 7, 2015 07:39 PM
