engine noice please help
Old Feb 11, 2009 | 11:59 AM
08GT4U's Avatar
08GT4U
thanks nuke and yes is a gt,i just chance oil to full syntethic and the noise is from 0 to like 3000 rpms
Old Feb 11, 2009 | 12:09 PM
Nuke's Avatar
Nuke
Did the knock on startup begin after the oil change? Do you know what weight oil they used?
Is the "dragging chain" sound there at idle? When you accelerate? Under both light and heavy acceleration? The more info you can provide, the better we can help.
Old Feb 11, 2009 | 12:52 PM
08GT4U's Avatar
08GT4U
the oil is RP 5w-20.the knock it has been there since before the oil change.
the knock is only at idle and with the car cold.once it gets to normal temperture it goes away.it feels like when a car is ideling at very low rpms and is about to die.but my idle is at 600 rpms.
the dragging chain noice is only when accelerating never at idle.is at light acceleration specialy between 1st to 3rd gear at normal speed.if i step on the gas i wont hear it since the engine starts to roar.
Old Feb 11, 2009 | 07:20 PM
charliebrown266's Avatar
charliebrown266
Maybe try taking the belt off before you start it cold and see if the noise is still there.If its gone then it is something driven by the belt!If it is still there could be from the motor.I remember seeing a tsb on noises from pullys on cold start,Or maybe it could be the plate between the transmission and motor!
Old Feb 11, 2009 | 08:08 PM
08GT4U's Avatar
08GT4U
ok the dragging chain noice to explain it better it sounds exactly as if my brake pad was leaning against the disk.like if something metal is spinning and another metal is toching it.
I have narrow it down to pulleys or brakes.
Old Feb 12, 2009 | 10:55 AM
sailing220's Avatar
sailing220
Where do you live (is it cold cold)?
Old Feb 12, 2009 | 08:57 PM
08GT4U's Avatar
08GT4U
miami and no is never cold here.today i took it to a shop and 95 percent sure is the right brake from what they saw.thank you all for all your information and help.
Nick Oliver
Oct 17, 2018 04:22 AM
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
rksnow1
Sep 14, 2015 08:46 PM
TfcCDR
Sep 14, 2015 12:08 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
