Check engine strategy code after custom tune?
Hey guys just a quick question for anyone that might have some ideas. The other day I loaded up a 87 octane tune after installing my JLT. The car ran well but it was really just a hold over until I ran the tank empty to put the 93 tune in. Well on Thursday I filled up with 93 and loaded up the 93 tune. After the tune was loaded I got a check engine and the following engine codes; p0060, p0141, p0155, p0161. I plugged the SCT back in and read the codes which all had to do with an 02 sensor heater. I cleared the codes and the check engine went away. I then decided to load the 87 tune back in and got the same codes. Again I read and cleared the codes. Anyone have any idea why I got these codes and why the 87 codes popped up the second time I loaded that tune but not the first? Some additional info: I have not made any mods to my 02 or exhaust outside of axlebacks. Second I did not return the car to stock between going from 87 to 93 or 93 back to 87, not sure if that's something that should be done or not to start fresh. The car seems to be driving fine on the 87 and the 93 before I returned to the 87, no knocking or pinging that I can hear. Performance seems on par with the 87 tune now as it did before when I was on 87 before the 93 flash.
Thanks for any insight anyone might have.
Hey guys just a quick question for anyone that might have some ideas. The other day I loaded up a 87 octane tune after installing my JLT. The car ran well but it was really just a hold over until I ran the tank empty to put the 93 tune in. Well on Thursday I filled up with 93 and loaded up the 93 tune. After the tune was loaded I got a check engine and the following strategy codes; p0060, p0141, p0155, p0161. I plugged the SCT back in and read the codes which all had to do with an 02 sensor heater. I cleared the codes and the check engine went away. I then decided to load the 87 tune back in and got the same codes. Again I read and cleared the codes. Anyone have any idea why I got these codes and why the 87 codes popped up the second time I loaded that tune but not the first? Some additional info: I have not made any mods to my 02 or exhaust outside of axlebacks. Second I did not return the car to stock between going from 87 to 93 or 93 back to 87, not sure if that's something that should be done or not to start fresh. The car seems to be driving fine on the 87 and the 93 before I returned to the 87, no knocking or pinging that I can hear. Performance seems on par with the 87 tune now as it did before when I was on 87 before the 93 flash.
Anyway, sorry I can't be of more help...
I've never had knocking with my tunes, 87 or 93, my issue was just a check engine code on the 02 heaters after the custom tune was loaded. If you are getting knocking that is a big problem that you should fix before you drive your car anymore.
One option is to return everything back to stock, and see if the codes go away. If they do, then reload the 93 tune. If they return, then contact the tune supplier for a possible tune related problem.
If the codes appear with everything stock, then there's a problem that's not tune related.
I had the same problem when I put my C&l on my car. I had no problem with the tunes the first time but after that anytime I change my tune I get the same codes about the 02 heater. From talking to alot of people I was told that this is a problem that alot of people are having and that this is normal now.
inyadreems
Aug 21, 2015 09:10 AM
