VERY loud ticking from engine...need help finding problem.
Old Feb 22, 2009 | 08:09 PM
one eyed willy's Avatar
one eyed willy
Default VERY loud ticking from engine...need help finding problem.
i recently got the turbo done and tuned at VMP, ran a 12.1 today at the track and it started making a very load ticking as i revved up the engine. so i turned it off and trailered it home. it sounds like its from the top end, sounds like maybe the driver side, but its always so hard to tell. i pulled the valve cover off on the driver side and i dont really see anything obvious. any help on finding the issue would be helpful.
Old Feb 22, 2009 | 08:13 PM
hardcore302's Avatar
hardcore302
Don't panic, but i think there might be a time-bomb under your hood, just step back...
Might be a bad exhaust leak, did you look at that?
Old Feb 22, 2009 | 08:20 PM
1slomofo's Avatar
1slomofo
my ticking under the hood of my blown gt was a rod lol.
check to see if you got any arching going on....
could be a number of things...
good luck with that one bro
Old Feb 23, 2009 | 05:26 PM
Ato's Avatar
Ato
Hard to say w/o hearing the sound but I had a similar sound when I spun a rod bearing which resulted in a roasted bottom end. Mine came from the bottom end w/ a severe loss in power and an oil pressure light. Obviously this isn't your problem since you ran a 12 in the 1/4 and hopefully not so severe.
It doesn't sound like a rapidly moving typewriter does it? That might indicate a valve, spring or retainer problem which I've also seen first hand.
Old Feb 23, 2009 | 07:08 PM
one eyed willy
yes,its rapid, i jacked the car up and its loudest thru the hole in the transmission. i used a stethescope (sp) and it was loudest on the rear of the valve covers and underneath.
is there anything in the clutch that could come loose? im still using the stock clutch. ill pull the tranny this weekend.
Old Feb 24, 2009 | 04:53 PM
Daniel60's Avatar
Daniel60
Mine used to do that at hard acceleration but I put some resline in it and it's fine. I was told that's noisy lifters. Anyway no more loud ticking.
Old Feb 24, 2009 | 04:54 PM
Daniel60's Avatar
Daniel60
http://www.barsproducts.com/100QR.htm
Old Feb 25, 2009 | 12:26 AM
rford426's Avatar
rford426
keep us updated ***** hope its nothing major
Old Feb 25, 2009 | 07:37 AM
one eyed willy
pretty sure its a rod or a valve , did a compression test and 7,8 cylinders are low.
Old Feb 25, 2009 | 08:21 AM
MustangGT0405's Avatar
MustangGT0405
How low?
