Help! Broken Spark Plugs
#22
OK, this thread just put the fear of changing my plugs now!!!!
I have an 2008 with 7K miles...not that I was planning on changing my plugs, but I like to know the details of maintenance items.
The only difference is that since my car is a Roush and the plugs are changed out...will I have this potential to break plugs with the Roush ones? I don't really know what kind of plugs they use.
Is this issue strictly with OEM Ford plugs or across the board due to the design?
#24
Stage 3 has the Roushcharger/blower... They said they change out the plugs and must use "Roush" plugs for replacement, otherwise warranty gets voided...
He is the link for the replacements: http://store.roushperformance.com/detail.aspx?ID=479
Damn, they look to be 2-piece design... Who the hell came up with this design?
#25
The only difference is that since my car is a Roush and the plugs are changed out...will I have this potential to break plugs with the Rich ones? I don't really know what kind of plugs they use.
The champions are a 1 piece type and are no more prone to breakage than any old style plug. You can lube the crap out of a new set of OEM plugs with copper anti seize on the barrel only, but it is asking a lot for it to stay on there for another 100K miles.
Sorry, I think ford recommends nickle anti seize.
http://www.fcsdchemicalsandlubricant.../tsb/06152.pdf
#27
That's because the cylinder head has a design problem and it's compounded by the fact the stock spark plugs are a two piece design that can't take a lot of torque when you try to twist them out. So they are prone to snapping off. Which can be a real PITA to deal with when it happens.
What is recommended? Remove them ASAP (preferably IMO before 20K miles) and follow the TSB. Put anti-seize on the electrode ground shield and then reinsert the plugs. Should be fine for a while. I wouldn't let them sit for 100K though as someone else mentioned. I'd pull them at least every 25K and reapply the anti-seize.
#28
#29
Damn, thats a real pain the a$$... I'll leave mine in there a little longer. Hoping Roush used some anti-seize when they replaced the plugs. Roush recommends a plug change at 25K miles or so...
I just can't get over how dumb this design is...
Thanks for all the help guys...
#30
Many just wait till 100K miles. Then let the garage do them with the tools, or at least that's the plan. Pull the head(s) if they have to.
