Mutha Thumpr cam review
#21
I was planning on doing the ***** Thumpr cams too. Would I need to degree the cams for best results? I'm doing all my parts all at once so I can just have the local dyno shop tune for everything. Going with:
-JLT CAI
-Pypes O/R X
-Charge Motion Control Valve (delete)
-***** Thumpr cams
-Comp 20% phaser limiter
-Comp or Manely springs
-Ported Stock heads
-91 Octane Tune
I already have 3.55 gears stock but will be upgrading to 3.73's as per comps recommended gear setup for the Stage 2 thumprs. I'm hoping for 380-400 RWHP with this setup.
-JLT CAI
-Pypes O/R X
-***** Thumpr cams
-Ported Stock heads
-91 Octane Tune
Now that being said, here is what I would do. Skip the springs (as they are not required with the MT's), CMCV delete, and forget about porting the heads. Get yourself some LT's, UDP's, and drop the rest of your the cash on a NO2 kit with a 75 shot. That my friend should get you over the 400RWHP mark. Beyond that, you need to look at forging the bottom end of the 4.6 motor IMO. Or just skip it all and get pricing for a FI kit from your favorite online retailer =)
HTH
~Matty
#23
crono,
To get the numbers you want you'll have to do as others have said and get some long tubes, all the other typical bolt ons, and a stroker (most likely with higher than stock compression too).
The new C&L intake manifold will help a lot once it's released. 17rwhp has been seen with it on a stock car and the more mods you have the higher numbers you'll see. I've been thinking about this intake myself. The only bad thing is it kills the option of a twin screw or TVS in the future.
#24
and i believe, your belief, is exactly right on.
this example is for the hot rods, but i believe it applies
to the thumper line also.
the biggest and imo the only important
factor with the hot rods vs. stock, is when the
intake valves begin opening.
as the piston is coming up during the exhaust stroke,
the stock cam begins opening the intake valves at
345*, compared to the hot rods which start opening
up at 311* (34* earlier).
so there's more time while both the exhaust valve
and the intake valves are still slightly open and
a very small percentage of intake charge can escape
out the exhaust port.
#26
-JLT CAI
-Pypes O/R X
-***** Thumpr cams
-Ported Stock heads
-91 Octane Tune
-JLT CAI
-Pypes O/R X
-***** Thumpr cams
-Ported Stock heads
-91 Octane Tune
You might want to look into Livernois cam lockouts and heads. They made 400 rwhp with their NA setup.
http://www.musclemustangfastfords.co...ade/index.html
#28
From what I've seen so far, you won't if you drive "normally." It's all in your right foot. But I guess it depends on where you drive and what other mods you have too. I've seen some impressive MPG reports with people using cams (Thumprs or Hot Rods and 4.10's, etc.).
#29
#30
Not sure you'll get 400RWHP with these mods. The stock heads will limit you.
Not saying that the numbers are bad, just for all of that you could always buy a pretty nice FI setup. Unless of course you are like me and just like building N/A engines to throw money at LOL.
HTH
~Matty
junior04
09-28-2015 10:53 AM
