o2 sensor
I had an o2 sensor go bad and replaced it with a bosch from Napa(about half the price of fords), cant remember the code(17100 maybe) but the text was "bank one lean" now my sensors read unready at the DEQ nad its been driven plenty......
If you want to diagnosis if the sensor is bad you can swap them front to back or side to side. This means you unscrew the O2 sensor, unplug the harness and put it in a different location. If you get the same code with a different sensor then it is not the sensor most likely and is going to be tune related.
Almost all after market tunes have the rear O2 sensors turned off.
jwog666
Dec 27, 2021 08:09 PM
TfcCDR
Sep 14, 2015 12:08 PM
