Old Oct 16, 2015, 11:50 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: General Overview
Print Wikipost
Jacking Up the Engine
Old Apr 17, 2009 | 05:43 PM
TPony's Avatar
TPony
Tell us your lessons learned once you finish the install...those are premium for the do-it-yourselfers......
Old Apr 18, 2009 | 10:58 AM
scoots's Avatar
scoots
Completed header install yesterday with a buddy of mine. Used a 2x4 and jacked up to the side of the oil pan where it bolts to the block. Worked like a charm. I was a bit nervous about it so as a backup i had a jack stand with a 2x4 on it just below the oil pan to "catch" the engine if anything went wrong. When jacking up on the side of the pan it will only jack up that side of the engine. We needed to lower it back down and jack up the other side to do the other header.
Scott
Old Apr 18, 2009 | 11:15 AM
157dB's Avatar
157dB
Cut & Paste Expert
Originally Posted by Riptide
Someone else here jacked it up by the pan and ended up with a crease.
I'd rather do it by the side one end at a time if it comes to that.
My oil pan is cast aluminum. How do you crease cast aluminum.
Would it not crack before creasing like sheet metal oil pans of the past?
Lift it from above with an engine hoist?
Or use the 303-F072 3 Bar Support Kit from Ford?
It looks like it could easily be duplicated with some
square tubing, some all-thread, washers and some nuts.
Why is everyone coming at the problem from below?
Pull instead of pushing?
Old Apr 18, 2009 | 12:51 PM
jahudso2's Avatar
jahudso2
Everyone has a jack and a phone book or wood. Very few people have engine hoists. Dont worry, I never jack the pumpkin
Old Apr 18, 2009 | 03:56 PM
Riptide's Avatar
Riptide
Don't know. I think it might've been moose that ended up with the crease. Not sure though.
Old Apr 19, 2009 | 03:45 PM
MadMike1337's Avatar
MadMike1337
this made for a good read i am installing JBA's on thursday through saturday on mine cant wiat!!!!!!!
how was your new found power? sound?
Old Apr 19, 2009 | 08:42 PM
shanec's Avatar
shanec
when I added Bassani LT's I got an instant bump in the butt dyno. But I was surprised to see it changed the sound very little. It got smoother, but not a bit louder or meaner.
Old Apr 19, 2009 | 09:01 PM
scoots's Avatar
scoots
Sound is fantastic. I think it really gives it more of the "old school" muscle car sound. I have the bassani x-pipe and it took away the high pitched raspy sound. You can hear the individual engine pulses as well. Also drone during highway cruising is gone.
I having an appointment for an update to my dyno tune tomorrow morning. I will update with results.
Scott
Old Apr 20, 2009 | 08:24 AM
MadMike1337
Scott
nice nice let us know how it goes. yea i have a magnaflow catted X sitting in my living room next to my headers too. i has sucked to look at them for the past week lol finally i have had some time to do it
Old Apr 20, 2009 | 03:47 PM
scoots's Avatar
scoots
I am pretty disappointed with the dyno results. I gained 0.5 rwhp and lost 3.8 rwtq. The headers did gain 3 rwhp and 3 rwtq at the top end though. The a/f ratio was rich which is the opposite of what should happen with more air flow. I did change spark plugs (autolite HT1's) in between these tunes and never did check if they were gapped correctly before I put them in. I am wondering now if there weren't. Guess I'll have to pull one and find out.
Scott
