TPMS??
Old May 11, 2009 | 03:30 AM
stealth_GT's Avatar
stealth_GT
Default TPMS??
I want to get drag radial track only tires but my car has TPMS (Tire-pressure monitoring system)
Is there supposed to be a special way to change out the tires and will having fatter tires trip the system off any?
I need to be able to swap out my tires at the track but don't wanna go farking things up on the system..
Old May 11, 2009 | 02:20 PM
bonestang's Avatar
bonestang
Couple of ideas:
Get a tune specifically for those tires and the race track. Just switch to it when you put the DRs on.
I dont think the TPMS is gonna be a problem. The car will probably tell you there is an issue with the TPMS but I doubt it will impact performance. The warning should turn off when you put the wheels with the TPMS back on.
I am gonna do the same thing once I get bigger rims for the rear. I'm gonna use the old 8.5" rims for a set of slicks.
Old May 11, 2009 | 04:11 PM
aclass's Avatar
aclass
You can either deal with the message on the message center. Switch out the sensors from your current wheels, or buy the entire kit from American Muscle for ~150.00 for your new set and be done with it.
Old May 11, 2009 | 07:16 PM
stealth_GT's Avatar
stealth_GT
that should do the trick.. I didn't even know they sold extra sensors for use with different tires.
That's pretty cool...
spectreman
Mar 31, 2016 09:26 PM
blueshawk
Mar 22, 2008 11:22 AM
blueshawk
Jan 14, 2008 12:37 PM
cartel
Wheels & Tires
Oct 11, 2007 06:54 PM
sycd
Wheels & Tires
Apr 21, 2007 09:52 PM
