Misfire Issues
Old May 22, 2009 | 03:08 PM
pumpkinhead's Avatar
pumpkinhead
Default Misfire Issues
I have an '06 GT with C&L CAI street, and a Bama 91 performance tune. Shorty headers, and a magna flow exhaust system. The car has a manual tran. In first and second gear at WOT the car performs great. But when I am in third at about 4500rpm it starts to misfire really bad. The same happens in fourth gear as well only at lower rpm, and not at WOT. I got a trouble code for the unplanned misfire on my predator. Does anyone have a clue what might be causing this problem?
Old May 22, 2009 | 07:44 PM
2007VistaBlueGT's Avatar
2007VistaBlueGT
Contact Bama and maybe they can send you another tune.
Old May 25, 2009 | 02:25 PM
modaddict's Avatar
modaddict
Also try checking your spark plugs...
Old Aug 7, 2009 | 04:17 PM
pumpkinhead
Thanks for the advice guy's. Doug at Bama said to check the plugs as well. I just finished putting in some new Champions and the problem is fixed. Car runs great now at any speed and rpm. Once again thanks!
Old Aug 15, 2009 | 03:58 PM
DLAP's Avatar
DLAP
I just drove the Alaskan Highway in a 07 GT. I have the same problem except the only aftermarket parts are a roush cold air intake and mufflers. Misfiring starts above 4500 rpm in second third and fourth gears. replaced the fuel filter, cleaned the injectors, replaced one bad coil and spark plug. Any other ideas?
Old Aug 16, 2009 | 02:14 AM
kj217's Avatar
kj217
i'd change the whole set of coils and plugs
cr620
Oct 3, 2022 10:18 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
Thunderball
15
Nov 22, 2015 11:49 PM
chrisdbassplayer
Oct 13, 2015 06:53 PM
Bokeo
Oct 10, 2015 08:28 PM
