Last edit by: IB Advertising
Browse all: Transmission Guides
- Ford Mustang Gt 1996 to 2004: How to Change Differential Fluid
Step by step instructions for do-it-yourself repairs
How To: Change Differential Fluid
#61
#65
But why does the official Ford Mustang manual say:
Rear axle lubricants do not need to be checked or changed unless a
leak is suspected, service is required or the axle assembly has been
submerged in water. The axle lubricant should be changed any time the
rear axle has been submerged in water. Fill 1/4 inch to 9/16 inch (6 mm
to 14 mm) below bottom of fill hole. Add 4 oz. (118 ml) of Additive
Friction Modifier XL–3 or equivalent meeting Ford specification
EST-M2C118–A for complete refill of Traction-Lok axles.
#66
#68
Thanks man I been lookin for this info for a good 30 minutes. Glad I finally found it thanks to you. I been wondering how to change that differential oil. Now i can do it myself and save the labor cost.
