WOAH Champion 7989.. NOT one piece plugs after all?
Errrr if this is true I am going to be PISSED.
I got mine a while back ago and am supposed to do the sparkplug switch next week...
Check it out...
http://www.svtperformance.com/forums...ark-plugs.html
Check it out...
I used to work for Champion when they were in Toledo. OH.
The blue ring you see on the plug is whats called the "hot lock ring".
The metal part of the plug is all one piece, the electrode is welded on.
When the plug is made the last step after the porcilin is installed is the
top lip of the metal is rolled over and a high current is applied while
about 10K psi squeezes the plug to seal it, the blue ring appears there
because it is machined slightly thinner than rest of plug.
I have never seen a plug break apart in that area.
I have been running Champions for 20k mi, I did have a problem with
one when I got them with a broken porcilin that caused a miss, but once
I got a free replacement been running great, I still pull them while its
in garage every winter to re-antisieze, they have looked great both times.
only the small electrode is welded on.
I was just sad to see they were made in Mexico, I was an electrician
at plant till it closed in '91, great job.
questions asked on the job application.
breaking
10-02-2015 01:27 PM
nmra1965
Other Professional Racing
09-26-2015 10:46 AM
