Does it hurt your car..........
does is hurt your car/engine, etc. if you consistently run through the gears above 3k before shifting to the next gear? Are these engines built to withstand driving them like this? I am in no way an engine/gear head and was just wanting to ask some of you guys that are. Thanks in advance for your thoughts.
JR
JR
Yes above 3k is fine. The car doesn't even make good power until 3,500 rpms. Just make sure you keep your rpms low and your load low when your engine is cold (if your water temp gauge is still all the way to the left). Once she is at full temp, give her hell.
/agree
Lots of other stuff will break way before your engine. Unless you really beat the hell out of it you should get at least 100,000 as long as you maintain it properly. Shifting at 3000 isn't going to hurt anything but your fuel mileage. And even then just barely.
JR
JR
i didn't know you could shift below 3k....seriously, it will just affect your mileage.
Seriously, sometimes I will drive like my grandpa for a week. It makes it so much more rewarding when I decide that it's over.
Shifting at or above 3k won't hurt these S197 engines and will actually keep them a bit cleaner (less carbon buildup) then if you were shifting at 2k or below. Shifting at a higher RPM means starting out at a higher RPM in the next gear and not lugging the engine as much. It WILL drop your fuel mileage a tad, however.
I can probably say that in typical "mindless" driving I shift around 2600 RPM. Spirited driving, it's close to or at redline all the way!
WarrenC
06-02-2004 02:49 PM
