I'm sure you're right, you don't actually HAVE to have a separator when NA, but these engines seem to have quite a bit of oil in the PCV stream. Getting this oil, or most of it, out of the air being put into the intake manifold has to be beneficial. I wonder if that isn't where a good bit of the carbon that cements the plugs into the heads comes from. I know a lot of Mustang owners (myself included) complain about occasional clouds of blue smoke on start up. Oil separators reportadley get rid of this too. I've seem pics of the butterfly plates in the heads with baked-on carbon that can only come from this oil. To me, it's a $100 improvment that I think can only help my engine. It is easy to install, looks good and from what I read, it works. Just my $.02.
With a NA engine, there should be minimal oil in the PCV stream, as there should be very little blowby. Even in high horsepower supercharged applications and modern engines there is very little blowby in the beginning of the engine's life cycle. I won't say that it doesn't help, as I have seen pictures of your oil catchers and have seen the little bit of oil in some of the cans. I am going to guess most of the baked on carbon is from use of regular dino oil. Synthetic oil has better heat transer qualities than dino oil, therefore, doesn't bake to the internals like dino does. There was a recent post on here about dino vs synthetic oil. A pair of engines with 100k miles or so each were tore down. Engine A had ran dino oil and had been changed at regular intervals and had the usual buildup and stains here and there. Engine B had synthetic oil changes and was clean on the inside. No deposits, no stains, no buildup.
I guess if it gives you peace of mind, then go for it. I was just curious, as I have seen very few used in high horsepower setups, and I, personally, have never used one in any build.
S197s create a fairly significant amount of blowby. When I installed my whipple, I pulled the stock upper intake off and oil dripped out of the runners. When I removed the throttle body, I found that the blades were soaked in oil. With almost 11psi, I get a couple of tablespoons in the catch can every 1,000 miles.
I pulled off my throttle body the other day, i'm N/A too, and had oil all over the back side it. I wiped around the inside of the intake manifold too and had some nast oily residue all over the rag. It was tan just like the oil I just put in it. Mobil 1 5w20 ofcourse.
When I saw the crap those two hoses dump into my intake that did it for me. I just bought the Steeda kit because it is see through and is pretty small. At the moment both sides of my 05GT are vented into the atmosphrere through valve cover breathers. I'll install the kit this weekend.
