Questions about forged stroker block asembly.
Old Dec 6, 2009 | 10:05 AM
JDWalton's Avatar
JDWalton
Originally Posted by mike castaldo
elec water bump, arp studs kit, felpro head gast, mel oil pump, morso oil pan, windage tray.. pay estra money and get coated rod barings.. that should get you started.. oh ya coat the pistons to help pervent detnation
i think your out of your mind. I keep talking about cheaper solutions and your trying to get me to buy every piece I can to trick it out and then link me a $17K motor... Where are the money savings in that. Dude, I see you put a lot of good info in people posts, but you pretty much always try to sell something from JPC too...
I am looking for a relatively cheap, reliable solution for a good gain from stock. Not looking for max performance win my division type of motor. If anything I think what Stkjock talked about with the aluminator is probably gonna be the most reliable way to get my boost up and reuse most stock pieces I can (i.e. save money)
Old Dec 6, 2009 | 10:37 AM
hammeron's Avatar
hammeron
it's hard for us to recommend parts or even
a build strategy, because we don't know
exactly what the budget is and the final rwhp
goal.
it's sounding more though like you would like to
do a practical build with limitations. in this
case, i think the build BruceH did, may be what
you are looking for.
Old Dec 6, 2009 | 10:44 AM
JDWalton's Avatar
JDWalton
goal.
Hemmeron, I'm surprised! you usualy dont miss posts
This was after the first list Mike gave me, that made me very surprised he would link a $17,000 motor
Originally Posted by JDWalton
Well mike, I am sure all of that would help, but I'm looking at how to do a basic forged internals cheaper, not get every possible upgrade. I'm wanting to safely drop in the... probably the 13 PSI pulley and some cams on the stock heads, then to move over everything else I possably (safely) can from my stock assembly. I belive this setup is equivelent to taking my stock block into a shop, having them bore it for me and installing the rotating assembly then reassembling. I belive I can do everything but the boring of the block, so if I can get the parts off the old block and then onto the new block, then flat bed it to the shop and all they have to do is time and tune, I am thinking this would save me tons of money. Looking to probably get this car into the 550-600 RWHP range. MAYBE a little more then that, but this assembly is supposed to be good well past that range.
Old Dec 6, 2009 | 10:48 AM
hammeron's Avatar
hammeron
what did i miss lol
i've been following the thread....i think mike
was serious on the first list, but after you
poo pooed it, he threw the second link in
for laughs.
i wish BruceH had done a detailed write up
of the budget forged internals build. it's
something a lot of folks try to put together
on their own, but aren't sure about a few
of the steps.
Old Dec 6, 2009 | 10:51 AM
JDWalton's Avatar
JDWalton
sorry had to go backand cut and paste the second quote, its up there now.
your right though, I wish there were some write ups. When I see people talk about doing this, I usualy see in the 6K+ range. It just seems like considering the cost of parts, you should be able to get it done much cheaper and still be reliable.
Old Dec 6, 2009 | 11:02 AM
hammeron's Avatar
hammeron
one of the questions, is whether you want to
surpass the torque rating of the stock
crankshaft. if you do, then you'll not only
need a forged crank but also an 8 bolt
flywheel. this could be $1000 added to the
build right there.
Old Dec 6, 2009 | 11:07 AM
JDWalton's Avatar
JDWalton
what do you think i would be looking at with the mods I have now, a 13 PSI pulley, and the twin screw cams
Old Dec 6, 2009 | 11:32 AM
hammeron's Avatar
hammeron
hard for me to say, but it might put you
around 550rwhp. if that was as high as
you plan to go, then doing a budget
build with just forged rods and pistons, is
one way to go.
Old Dec 6, 2009 | 11:37 AM
JDWalton's Avatar
JDWalton
well the setup I linked here:
http://www.stage3motorsports.com/pro...d_Pistons.html
does come with the steel crank also. I guess that just leaves me questioning the flywheel.
Old Dec 6, 2009 | 11:48 AM
hammeron's Avatar
hammeron
power is so darn expensive!
$6000 to go from 265rwhp > 500rwhp
$5000 to go from 500rwhp > 600rwhp.
