3rd gear going out?
Old 03-06-2010, 06:01 AM
tbuff
tbuff's Avatar
Default bogging in 3rd gear
I just bought my car a few days ago. IT drives fine. I've gotten on the gas pretty good and everything holds up fine. Well last fine I finally got on it 100% WOT and really running through the gears hard. When I got to third gear it was like I hit a brick wall and nothing happens. But as soon as I let off the gas and press it back down, it engages and then takes off like normal. It's like it's just not grabbing in 3rd when I am putting it in gear at a higher rpm and really hard. On a scale of 1-10 as far as acceleration and shifting hardness goes, it only does it at about 8.5 and higher. It catches fine in every other gear, so obviously it isn't the clutch. What do you think it is, and also, how much do you think it will be to fix. Secondly, does ford have a powertrain warranty that is transferable? Mine is not a certified pre-owned. Mine is an 06 GT with about 9k miles. Thanks in advance guys.
tbuff is offline
Old 03-06-2010, 06:05 PM
tbuff
tbuff's Avatar
ok. so it's prolly not the transmission since it actually engages and the rpm's don't climb at all. talked to one of my techs today and he told me that since the car sat around for a while at the dealership, that there could be something on the MAF sensor. So i'm gonna clean that off, and clean the throttle body as well and see if that helps.
tbuff is offline
Old 03-06-2010, 09:30 PM
jahudso2
jahudso2's Avatar
It's the remote shifter linkage on our cars. When the engine and tranny torque over under load, the shift linkage binds up and does not let you select third gear. You need torque limiters or stiffer motor mounts to keep the engine and tranny from rotating so much under load. Then you won't miss third in high load situations.
jahudso2 is offline
Old 03-07-2010, 07:32 AM
tbuff
tbuff's Avatar
so I take it that this is very common in these cars then? How did something like that not get fixed by Ford?
tbuff is offline
Old 03-07-2010, 10:05 AM
candymanjl
candymanjl's Avatar
in the end, it's still a ford
I get that issue now and then, I find that it's fine if I'm real deliberate with my shifts, if I get a little lazy I'll mess up.
they have a tough job building these cars, 99% of people want it to be really quiet and smooth over us who want the most performance and are willing to sacrifice other things. so the majority wins and we have to fix stuff like this, it's not the end of the world.
candymanjl is offline
Old 03-07-2010, 10:09 AM
East87
East87's Avatar
Yea +1. Got the K-member brace with torque limiters...it's a really awesomely underrated mod.
East87 is offline
Old 03-07-2010, 10:54 AM
candymanjl
candymanjl's Avatar
did that add any noticeable vibration or noise? looks like an easy mod to install.
Old 03-07-2010, 05:15 PM
tbuff
tbuff's Avatar
where can I find that?
tbuff is offline
Old 03-07-2010, 05:46 PM
East87
East87's Avatar
Not that I could tell. Everything just felt stiffer and shifting was much more solid.
Right here: http://www.brenspeed.com/che7la.html
East87 is offline
Old 03-07-2010, 06:52 PM
tbuff
tbuff's Avatar
just went back and re-read your post. my car goes into gear. but it's when I let off the clutch and push the gas is when it basically just bogs hard. so I am able to select the gear
tbuff is offline
Quick Reply: 3rd gear going out?
