Another Fuel Pump Question
I did search through the multiple post regarding fuel pumps but i want to be sure.
Problem my car is out of warranty and I am suffering from the fuel pump TSB I believe. So instead of just changing the stock pump out I want to upgrade to the GT500 set up.
The questions I have is will i require a new tune and do i need to add the KB boost a pump.
Currently I have the stock pump and 20 amp boost a pump.
I am sorry if this has been covered but I did look and could not find it.
Thank you
Thank you
the dual GT500 pumps are supposed to be good till about 600hp so you'll be good for a while. unfortunately your single BAP won't work with the dual pump setup. they sell a dual BAP for the GT500 pumps, it's like $450. unless you're going over 600hp you don't need the dual BAP though.
