2010 Corsa X Pipe?
I talked with a tech at Corsa a while last week and it seems their design for the exhaust is the same for 05 - 10. Basically the part numbers should be the same for all S197s. I told him the rear facia was longer and that FRPP and Borla needed longer tips, but they said theirs fits fine. X pipe requires a cut and fit so it should be OK as well. I was looking at the Xtremes, how do they sound and did they fit properly? Still debating the Xpipe. They are pretty helpful there if you call the number on their website.
The xtremes sound awesome, has a perfect sound. No drone like advertised, great product. They fit properly but its not 100% perfect. Its seems on all mustangs the right tip is a little off centered. I got them to look about right from a distance, nothing to worry about. They also extend out far enough.
On the x pipe, I called the dealership and they said an x pipe will not void warranty, but if I take my car in I should take it off...Doesn't make sense.
You're right that doesn't make sense. You could always have the dealer install a FRPP X pipe, which definitely will not void warranty, it's a Ford authorized pipe installed by Ford dealer. Not sure of the difference between the two X pipes, except I imagine the Corsa has a better warranty, maybe higher quality steel. Seems to me an X pipe is an X pipe. Thanks for the info on the extremes, thing that's a done deal on my end as soon as I get to it.
Galactic
04-29-2019 02:56 PM
09-24-2015 09:18 PM
trashxtrash
09-20-2015 10:49 PM
