BBK Throttle Body?
Old Jun 30, 2010 | 11:09 PM
drewsky's Avatar
drewsky
Default BBK Throttle Body?
BBK swears that their throttle body will give 15-20 xtra hp! from what ive been reading on this site is that they are a waist of $$ unless you have a supercharger... for 300 bux 15 hp doesnt sound like a bad deal! has anyone had experience with these at all?
Old Jul 1, 2010 | 06:53 AM
Nuke's Avatar
Nuke
Plenty of experience, especially if you use the search feature. If you believe manufacturer claims, then I have a bridge to sell you.
Old Jul 1, 2010 | 01:21 PM
Diabolical!'s Avatar
Diabolical!
Pure waste of money.
Old Jul 1, 2010 | 11:16 PM
SirKnightTG's Avatar
SirKnightTG
BBK is full of ****.
The only way that would happen is if the stock TB was as big around as a quarter.
Old Jul 2, 2010 | 06:02 AM
Rob72's Avatar
Rob72
It's closer to 5 hp.
Old Jul 2, 2010 | 08:44 AM
BruceH's Avatar
BruceH
The stock tb flows 925 cfm. Think about the old days when going over 650 on a 350 was too much. There is a point where a bigger tb will help but the stock unit will support alot of hp, more than most supercharger kits can give.
Old Jul 2, 2010 | 11:11 AM
157dB's Avatar
157dB
Cut & Paste Expert
Expensive doorstop/lesson
Keep the OEM TB and tools in the trunk
when the BBK takes a sheit at the worst
possable moment...
Old Jul 2, 2010 | 01:31 PM
Goldenpony's Avatar
Goldenpony
The manufacturers of the Turbinator swear their product does EVERYTHING. Keep your money in your pocket.
Old Jul 2, 2010 | 08:11 PM
SpartaPerformance's Avatar
SpartaPerformance
I installed the GT-500 TB with a spacer plate and without a tune I felt a difference. 10-15HP That's pure BULLSH$T I'ld say 5 but it's across entire RPM range so it's worth it buuuuuuuuuuttt not the BBK because you have to swap electronics. a FRPP unit comes with new already set electronics. You can get a GT-500 twin 60mm for $150, one of those spacer plates for like $20 I think and longer bolts and still be cheaper then BBK and its bolt on and go.
Old Jul 2, 2010 | 10:46 PM
jz's Avatar
jz
Wait, you're kidding right? I wonder if I can return this thing?
UrS4
Oct 3, 2015 06:23 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
guitarman376
Sep 30, 2015 05:54 PM
GLOCKer
Sep 28, 2015 07:36 AM
2poor4u2
Sep 26, 2015 11:08 AM
