need imput
Old Jul 28, 2010 | 11:01 AM
07black_gt's Avatar
07black_gt
Default need imput
im having this rattling kind of noise on the left side of my car when i take off slow with the rpms around 900 rpms , idk what it is, but i am hoping that somebody can give me a straight up answer its comming from the drivers side and the noise goes away after 1000 rpms, idk if something is lose or what it is, imput would be apperciated greatly thanx
Old Jul 28, 2010 | 11:18 AM
mapitts's Avatar
mapitts
Check your exhaust clamps at the H pipe and the mufflers. While you are under there make sure that the exhaust is not coming in contact with anything. That noise will drive you crazy.
Old Jul 28, 2010 | 11:34 AM
Nuke's Avatar
Nuke
Those are 2 of the 3 more common reasons for this type of noise. The 3rd is heat shield vibration. I had it as a metallic rattle in the 1600-1800 RPM range and it was the axle back clamps needing about another 1/4-1/2 turn additional torque.
Old Jul 30, 2010 | 10:49 AM
07black_gt's Avatar
07black_gt
oh ok, any other imputs? its commin from the frount
Old Jul 30, 2010 | 11:20 AM
mapitts's Avatar
mapitts
If it is the heat shield, it will conduct the noise in the pipe and it will sound like it is in the front. Is it a metal on metal noise? Or is it just a noise? You are saying that it goes and comes at a certain rpm so that leads me to believe that it is something drivetrain / exhaust related.
Old Aug 7, 2010 | 01:19 PM
07black_gt's Avatar
07black_gt
umm im not really sure what kind of noise, jus like a vibraitin noise tho, idk where it is commin from, its really buggin the heck out of me tho, it only happens around 850 1000 rpms, it might be jus a noise tho
Old Aug 7, 2010 | 01:22 PM
07black_gt's Avatar
07black_gt
oh ya i just went an looked at the heat sheild and it was like rubbin or it looked like it was so i jus bent it back and it still makin a noise ugh
Old Aug 7, 2010 | 02:48 PM
Nuke's Avatar
Nuke
Have you torqued the midpipe and axleback clamps another 1/2 turn or so like I mentioned earlier?
Old Aug 8, 2010 | 05:44 PM
kpd1031's Avatar
kpd1031
Imput?
jthorn9
Feb 22, 2006 01:37 PM
ricklmesa@cox.net
Feb 15, 2006 05:47 PM
66ckurt
Feb 11, 2006 06:05 PM
90Mustangfan
Apr 7, 2005 03:19 AM
artisan00
Mar 11, 2005 03:53 PM
