Ported Heads, new heads, or FRRP intake?
I don't like posting too many links to other forums, but over at Allfordmustangs.com they have a few members claiming 400+whp with the FRPP top end kit. ONe of them went all out with a built motor making 439whp (7400 rpm)with all the fixings.
Of course, by that point it costed a ton of money and you could get that with a blower.
It would be nice to have all that power without the excess weight and other stuff mounted on the front of the motor (supercharger, intercooler, plumbing, coolant etc.)
Bruce, I don't think it's quite apples to apples when you are talking an NA car versus an FI car with a built motor.
If you or I could do heads, cams and LTs at the same time it could be worth 60-100 hp depending on how wild you get.
Stroking the motor and raising the compression ratio will gain you both HP and Torque across the board. HP won't go up tremenously and the torque curve will be much flatter (and higher), but nothing like a positive displacement blower. Bolt on mods for N/A cars are going to focus on the top end and the low end will suffer. That's just the way it is.
why are you dicking around with all these little mods for 10-20whp at most when you can bolt on a V3 non-intercooled and gain 150whp (93 octane gas)?
NA is cool and all but without a built motor with high compression and high flow heads with aggressive cams, its not worth it imo in terms of getting the most out of the stock motor...
just imo.
just imo.
You know what they say.
If you want to get a SC it's best to make sure you have the cash for a new motor JUST in case.
I am enjoying adding a little bit at a time to the car and keeping it N/A.
Besides, there is a lot of difference in spending money when you CAN and commiting yourself to another payment if you were to get a loan for a SC.
And I don't have the cash to drop all that down at once.
As far as saving my money for a good while untill I got an SC or something....
again I enjoy adding little amounts here and there, and I can tell a difference in the way the car performs. And agian... I would have to have the backup cash or ability to purchace a new engine if something catastrophic happened BEFORE I felt comfortable with strapping a SC on it... regardless of how "safe" they are these days.
Call me paranoid but that's the way I operate.
Plus again DAMMIT! I just like doing N/A and taking it slow! It lets me enjoy
the acutall work. Throwing something on there and just being done with it takes all the journey out of the ride man in my opinion man!
I thought people were getting great results with comp stage 2 heads and cams.. I know i've seen some really impressive 1/4 mile numbers from people with those.. even if you lose a little down low when you are racing it you probably wont be much lower than 3-3.5k rpm right?
but yeah.. It will cost about as much as a blower. being in TX that wont be a problem for you.. I think it's neat to stay N/A and would do heads but the low air pressure up here means I have lower compression than you guys near sea level... I need more boost to make up for it... i can also run lower octane gas w/o detonation... (or i could advance the timing more)
Well, its not real safe to assume that a full-on NA build putting down that much rwhp is going to be any safer than a blower doing the same thing. The stock internals are still going to be the weak point, regardless of how that power is ultimately getting there. Just MHO of course.
That said, NA builds are cool and all, but they do cost the same or more as FI... so you really just have to want to do it for it to make sense I think.
