bama tune problem! please help
Old Mar 11, 2011 | 06:02 PM
10stang10's Avatar
10stang10
Default bama tune problem! please help
Just downloaded a bama tune to my mustang and now my car wont start! tried to put the original tune back on but the diablosport predator tuner says my car is not on and it is. engine wont start but i can turn the car on! tried disconnecting my battery for ten minutes and nothing happens! any suggestions?
Old Mar 12, 2011 | 01:08 AM
Dens2010GT's Avatar
Dens2010GT
did you load the right tune. it should be one of your preloaded tunes, i wasnt paying attention to my tunes when i reprogrammed after my headers, and loaded the wrong tune and it wouldnt start. You should be able to get the programmer back on, go to your load tune screen, and select your PRE LOADED tune. Hope it helps
Old Mar 12, 2011 | 08:05 AM
10stang10's Avatar
10stang10
when i try to load up any tune including original tune it says "please make sure the car is on and engine is not running" and the car is on! ill be calling bama tunes to see if there is a way i can fix it!
Old Mar 12, 2011 | 08:18 AM
gman73's Avatar
gman73
You are turning the key to the 2nd click?
Old Mar 12, 2011 | 08:37 AM
10stang10's Avatar
10stang10
yea its the second click!
Old Mar 12, 2011 | 05:31 PM
Dens2010GT's Avatar
Dens2010GT
it says that any time you install a tune, you have to hit a "OK" button (or something similar) and then move onto the load.
Barcafut13
Sep 1, 2015 06:08 AM
kevans79@yahoo.com
Aug 18, 2015 09:01 PM
antipeterleague
Aug 18, 2015 01:50 PM
whatsup62
Aug 11, 2015 08:45 AM
dragman72
Aug 9, 2015 12:54 AM
