PI SWAP PROBLEMS PLEASE HELP
Old Apr 16, 2011 | 10:54 PM
98gtmustangpi's Avatar
98gtmustangpi
Banned
Default PI SWAP PROBLEMS PLEASE HELP
ok first off thank god for this forum and all the great people on here!! now thats out the way here is my problem i decided to do a pi swap on my 98 mustang gt the guy who set the timing set it to the old heads instead of starting over a TDC... so when i tried to start the car "smack" i hit the passenger side valves and bent 4 of them..it broke the timing chain etc etc.. i pulled that head and had all valves replaced AGIAN because i had the heads shaved .30 thousanths and i had them "pocket ported" and decided to do the swap 100% right no shortcuts anyways my problem is this i had those valves replaced i set the timing at TDC cams and crank and started the car it ran fine but it lacks power!! A moped will out run it!!!! the passenger side exhaust pipe blows out hot exhaust and the drivers side is cold what do you all think the problem is?? is it possible the driver side valves are also bent it sounds like its "CAMMIN" really hard and it shakes the car!! i checked for vaccum leaks i mad sure all my wires on the harness is plugged in etc etc.. the only other mods i have is mac cold air intake, bbk off road H pipe,flowmaster super 44's other than that and the swap its stock i also replaced all sparkplugs to match the 02 heads i put on it any help will be greatly appriciated thanks agian john
Old Apr 18, 2011 | 11:11 AM
Diabolical!'s Avatar
Diabolical!
You're in the wrong section. Try the SN95 section. Good luck with the problem.
Old Apr 18, 2011 | 02:57 PM
98gtmustangpi
Banned
ok thanks man!!
Old Apr 18, 2011 | 09:17 PM
SpartaPerformance's Avatar
SpartaPerformance
I'm betting the cam on the cold side is no where near set straight line with the proper crank position and your blowing intake right out the exhaust port.
Old Apr 18, 2011 | 10:59 PM
98gtmustangpi
Banned
i set the driver side cam which is blowing cold air around the 2 o'clock postion?? like it said in the chilton shop manual
Old Apr 19, 2011 | 08:56 AM
98gtmustangpi
Banned
ive heard something about the cams have to be degreed right when they are installed on the head and i called the machine shop the pocket ported them heads and shaved them and he acted like he had no idea what he was talkin about?? i have bolt on cams they can only go on one way right?? or am i wrong??
Old Apr 19, 2011 | 09:14 AM
98gtmustangpi
Banned
what i meant to say is bolt on cam gears
Old May 2, 2011 | 09:11 PM
98gtmustangpi
Banned
bent all the valves but 2 plus broken valve guides was mu problem im putting it back together now!!
Golfsito
Oct 6, 2015 11:02 AM
97SN95GT
Sep 13, 2015 09:45 PM
vintageaion
Sep 8, 2015 10:45 AM
zanemoseley
Sep 6, 2015 12:58 PM
5.0 kevo
Sep 3, 2015 06:24 PM
