Help im getting a bad knock/misfire under wot in 3rd gear??
I have an O6 GT convertable. Im getting a bad knock and check engine flashes under WOT in 3rd gear. I ran a DCT scan and it gave me a P0300/ Miscellaneous misfire code. Btw I have a JLT cai along with sct program. Iv been running the program about 5 month but jus started with this issue. Also Im running the 91 program and always run 91 plus a octane booster. Wolud love any input. Thanks..
Srry im new at this. Thanx for ur responds but, i didnt help me much. Its not the tune iv ran it for bout 5 months. you said detonation yes but from what where, what wud cuz that? another thing u said go the stock setting and work from there???
Second, have you tried loading a less aggresive tune to see if your gas is the culprit? Maybe they filled the 91 tank with 87 and now you're hearing it...
Don
I'm thinkin bad gas. Go to a different tune that requires a lower octane like BigDinTexas stated.
if the problem goes away, then you know it was bad gas. If it doesn't go away then it could be a bad plug or coil.
musnicki
09-23-2015 07:11 AM
