power loss at take off
why do i have loss of power at takeoff but after rpms go up power kinda kicks back in. I have changed plugs,fuel filter, and air filter. the check engine light is not on but battery light and abs light on. where should i start?
Ditto. And you shouldn't have any lights on. The board should be clear, other than the TCS showing "OFF" after you manually disengage the lil' bastard.
If you're talking about the power surge around 3000 RPM, then a good custom tune may be all you need to smooth that out a bit.
KingRando
10-02-2015 08:06 AM
09-25-2015 06:58 PM
