Tach Problem - Stepper Motor
Old Sep 6, 2011 | 01:39 PM
2005BlackGT's Avatar
2005BlackGT
Default Tach Problem - Stepper Motor
My 05 GT is now having a problem with the tach facing in the six o'clock position. The needle still moves, but does me no good like this. After some researching, I'm suspecting I'm one of the lucky ones with a stepper motor that's failing. The warranty expired and I'm trying to figure out my options here without paying a large cost at the dealer to fix it. Any suggestions are greatly appreciated. Thanks.
Old Sep 8, 2011 | 12:17 PM
2005BlackGT
No replies to my original post, but found this link while doing research. Posting here for the next guy that has this issue.
http://www.ratstangrestoration.com/S...ent%20Pack.htm
Old Sep 8, 2011 | 02:03 PM
rdsx18's Avatar
rdsx18
Didn't see this thread earlier, but ya, follow that, I had the same problem as you and replaced my stepper motor and it was fine. I'd do all the motors too, or at least the speedo while you are in there. To de-solder it, I would bring it to somebody unless you are confident in your skills. I was able to get the new ones on, but did not attempt to take the old ones off.
Old Nov 28, 2011 | 11:34 PM
RedDominion's Avatar
RedDominion
The Tach, Oil, and gas gauges are not working in mine. When I brought it to a Ford dealership they said I needed to replace the instrument cluster. I'm going to try the steeper motors and see if that will fix it.
Old Nov 29, 2011 | 07:35 AM
Nuke's Avatar
Nuke
Another example of a dealership doing what is easy and makes more money for them and costs you more.
Old Dec 5, 2011 | 09:50 AM
Lethaldosage423's Avatar
Lethaldosage423
I made a how to on this from my sixxer. My oil pressure gage was bad so I replaced all the stepper motors
I'll look for it when I get off work for ya
It's tedious woek
Old Dec 5, 2011 | 08:16 PM
Lethaldosage423
https://mustangforums.com/forum/2005...r-cluster.html
Old Dec 11, 2011 | 12:43 PM
02WhiteGTVert's Avatar
02WhiteGTVert
I had to do this on my '05 GT because of the same problem...
i never soldered anything before but I ordered the motors off of Ebay and bought a soldering iron from walmart (around $5). I used a bit of a different technique though...instead of removing the solder from the holes, i alternated between pins on one side with the iron, while slightly pulling up on the side of the motor...as the solder heated it would released the pin a few MM's...to install the new ones i did the same thing...alternated on the holes while pushing the motor through...hooked everything up and works perfectly!
Old Dec 12, 2011 | 10:12 AM
RedDominion
That's the correct trick! My first attempt at removing the stepper motor was very difficult. I thought during the desoldering process I would have to remove all the solder first. That didn't work. So I did the same as you, touching the iron at each joint and then pulling outward on the motor. I could hear a slight click noise each time I edged out the motor and kept working in a circle until it finally came out. The last two took only a few minutes to finally remove. This is by far the best money saving project, saved well over $500.
Old Feb 3, 2012 | 12:27 PM
16CrewChief's Avatar
16CrewChief
All the gauges are out on my '05 GT. The RPM was the first to go, then the speedo and temp soon after. After poking around the internet, this is a known problem with '05's. Boggles my mind that Ford hasn't issued a recall on this KNOWN problem. Instead of shelling out hundreds for a cluster repair/new cluster, I ordered the stepper motors off EBAY...weekend project
Granatelli Sales
Jan 20, 2020 12:34 AM
musnicki
Sep 23, 2015 07:11 AM
5.0 kevo
Sep 3, 2015 06:24 PM
daytooday
Aug 11, 2015 09:22 AM
