Gas pedal out of touch with engine ???
I have an 05 GT automatic. Last night as I pulled away from a stop sign I thought my engine died. turns out it was still running but lost communication with the gas pedal. I stopped, cycled the key once and everything went back to normal. How common of a thing is this and should I be concerned? Engine light never came on.
It was just like in the old days when the throttle cable would pop off at the carb, except now there is no cable. I did talk to a Ford tech yesterday who said that was rare. He said it may never happen again.
Anyone else experience this???
I have been driving it a bit since. It has never happened again.
Checked with a Ford tech who never heard of it either and said it may never happen again.
Wow run into new things everyday!! At this point you may have to wait until the concern manifests itself again, more frequently or worse symptoms. All the throttle concerns I have experience with have led to bad throttlebody electronics, 55k is young for malfunction but it could happen. What I would do is remove the T-body and clean it make sure there's no carbon/oily build up. Who knows what kinda crappy maintenance previous owner performed.
Did you get a wrench light on the cluster when this happened? I could actually be either the tp sensor or the accel pedal sensor. Could be a loose or partially pushed out wire somewhere too.
