The evil 0340 code
Old Sep 5, 2013 | 05:18 PM
BFMacias's Avatar
BFMacias
Default The evil 0340 code
Fellas,
I have been combating the evil 0340 code to no avail what so ever. I have already replaced the alternator and my cam position sensors. When I first threw the code the car was running which leads me to believe there shouldnt be any problems with wire continuity. I have researched this code on here pretty deeply and can't find sh*t else to check. It is driving me crazy! Can any of you give me some higher level expertise here?
Old Sep 5, 2013 | 06:24 PM
Nuke's Avatar
Nuke
Have the alternator tested (I know, you already replaced it) for excessive ripple. Rebuilt alternators AND Ford alternators are garbage. The only replacement I would trust is a PA Performance alternator.
Old Sep 5, 2013 | 07:02 PM
BFMacias's Avatar
BFMacias
I just replaced the alternator with a PA performance one however still have the same issue. Thank you Nuke, you are the type of response I was looking for.
Old Sep 5, 2013 | 07:03 PM
BFMacias's Avatar
BFMacias
One thing that has made me curious is that after replacing the alternator the check engine light did not illuminate. However after the second start the check engine light came back.
Old Sep 8, 2013 | 12:24 AM
Simon1's Avatar
Simon1
Two things: Did you fully charge your battery before installing a new alternator? Alternators are made to maintain the charge not recharge the battery. You can burn up a new alt by making it recharge a poorly charged battery. Test the battery too.
Is it the same code as before?
I got areplacement alt from napa and it lasted 4 months. Just out a new one back in. We will see....
BOB ROME
Jul 26, 2023 01:54 PM
mrtrodonet
Sep 19, 2020 03:12 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
Dathan
Oct 5, 2015 05:52 AM
ChampInSD
Oct 2, 2015 04:55 AM
