mustang bullitt 2008 engine dies on idle
Thankfully the issue was solved. As I expected the problem was caused by the maf sensor. After trying another sensor I saw no difference so I thought about checking the connector itself. The wire which supplies the power to the sensor was the shot. I traced it back to the fusebox and discovered that an electrical short in the fusebox caused this wire to loose its power supply. So I checked the fusebox and every fuse worked and no issues with anything else but this particular wire. The guy I took that car for connected this wire to the wire that supplies power to the injectors and the issue was fixed. He guaranteed that there is no need to replace the fusebox since now the maf sensor takes its power from the injectors line and that has a fuse already and also everything else works . What do you think guys ? I mean what caused that short in this specific wire ?
Thanks.
Thanks.
Thanks.
Thanks.
The only reason I know this is because it happened to me. For tow months I chased an electrical gremlin and finally gave up. I took it to a shop and the guy figured it out and explained it. What pissed me off is that I knew that circuit was the problem and that the connection had stretched. I just wasn't smart enough to figure out the solution. $400 later, a fuse, 10 hours of fuel, and a piece of tin foil later, I got my car back.
MEISTERSNFB
03-31-2020 07:50 AM
HIS S-197
08-10-2015 05:47 PM
