Alternator?
Old Aug 27, 2016 | 12:41 PM
alsGT's Avatar
alsGT
Default Alternator?
I have two trouble codes. P0390 and P0394. Cam position circuit B intermittent.
They aren't P0340 and P0344 but are they a result of a bad alternator?
All help appreciated
Allen
Old Sep 2, 2016 | 09:06 AM
alsGT's Avatar
alsGT
Engine has been turning over very slowly in the last couple of days. I found the negative terminal post of the battery, at the bottom, had almost completely broken away. A pencil thin piece of the post in the center was the only connection.
I replaced the battery, cleared the P0390 and P0394 codes.
Code P0345 showed up 15 minutes after starting. I cleared it. Drove to work this morning and the code returned.
I do seem to have an occsasional miss at idle. It is noticeable.
Any inputs?
Here is the negative terminal post.
Old Sep 2, 2016 | 12:33 PM
Goldenpony's Avatar
Goldenpony
Have you had the alternator tested?
Old Sep 2, 2016 | 05:05 PM
alsGT's Avatar
alsGT
No, but I'm aware of the TSB for earlier Mustangs. I will be picking up an oscilloscope this weekend.
Old Sep 2, 2016 | 06:50 PM
jz78817's Avatar
jz78817
yeah, excessive ripple coming from it (failed rectifier) can cause all sorts of issues.
Old Sep 7, 2016 | 05:12 AM
alsGT's Avatar
alsGT
Well, after being on for a week, even after resetting, the engine light went out late last night. Still no code this morning.
Hmm.. :^|
kerrysch10@hotmail.com
Aug 24, 2016 05:07 PM
4.o stang
Aug 16, 2016 07:57 AM
jlopez07
Jul 11, 2016 01:40 PM
Drastang
42
Jun 18, 2016 09:59 AM
spiceyhott
Jun 1, 2016 10:03 PM
