2006 Mustang Electrical
Old Apr 19, 2018 | 09:02 AM
Porter1's Avatar
Porter1
Default 2006 Mustang Electrical
I am having an issue with my 2006 Mustang GT. If I step on the brake pedal with the key out of the ignition all of the dash lights, warning lights and radio come on. it is as it I just turn the key to the run position. I am at a loss as to where to begin to look for the issue, Any input or suggestions would be greatly appreciated.
Thanks
Old Apr 19, 2018 | 09:55 AM
Dino Dino Bambino's Avatar
Dino Dino Bambino
You may have the well-known water leak from the cowl into the front passenger side footwell via the cabin air filter. Check if the carpet is wet and if there's water contamination of the SJB.
Old Apr 19, 2018 | 10:32 PM
08'MustangDude's Avatar
08'MustangDude
Banned
Tomorrow, I am going to shield my SBJ tomorrow. I am going to use Dynamat to
shield it from water, just in case. I plan to put the Dynamat over it, then cut a vent
slot down the center. OR a raised wall of Dynamat around it. Will also look
into changing out the drain plugs with something more reliable...
Old Apr 20, 2018 | 07:09 AM
artsvettes73's Avatar
artsvettes73
I find that if you check the drain plugs at every oil change it becomes a non issue. Granted it only benifits those that change their own oil.
Ibrokeit
May 12, 2012 11:41 AM
toprankfedor
Apr 5, 2010 10:38 AM
johnny1973
Nov 15, 2008 02:14 PM
92hatchLX
Nov 15, 2006 11:10 AM
Kargstang
Jun 2, 2006 12:53 AM
