Rear End Noise from My 2005 Mustang Gt
Old 11-16-2018, 04:31 PM
  #21
bl817
bl817's Avatar
Norm, I believe that is a body brace for a convertible car. OP, the axle vent is on the passenger side. if you were sitting at the rear pass tire, its past the bump stop. ive seen plenty of pinion seal leaks account a clogged axle vent, never anything like the leak on the drivers side. IMHO, your drivers side axle tube has somehow "moved" in relation to the center section (where the gears are) and caused the leak. that said, since the oil is on all the tube, hard to say. something is amiss for sure. look on your local or nearby CL for a new rear axle or pull yours off and have the tubes welded to the center section. good luck
bl817 is offline
eatmyjeep
10-14-2011 07:15 PM
cstack80
03-29-2009 11:39 AM
woodly1069
04-29-2008 01:35 PM
leglocking101
12-14-2006 05:29 PM
REN06GT
10-08-2005 10:42 PM
Quick Reply: Rear End Noise from My 2005 Mustang Gt
