Idle problem
Old Jan 24, 2019 | 05:33 PM
Albert Hingpit's Avatar
Albert Hingpit
Default Idle problem
Hey guys new to the forum,
im having an idling problem with05 mustang GT. When im on idle it starts to die and I have to rev the engine to stop it from dying. I put a new alternator, battery, spark plugs, and ignition coils. I clean the maf sensor and throttle body and I check all vacuum lines to see if there's and leaks or crack, at this point I don't know what's causing the problem.
Old Jan 25, 2019 | 01:24 AM
Dino Dino Bambino's Avatar
Dino Dino Bambino
Disconnect the negative battery cable for 10 minutes to reset the ECU. Then reconnect and follow the idle relearning procedure as described in the owner's manual.
http://ricksfreeautorepairadvice.com/ford-throttle-body-relearn-procedure/
Old Jan 25, 2019 | 11:42 PM
Albert Hingpit
Thank you dino
Pablo Hernandez
Mar 28, 2019 02:18 AM
mojopony
Sep 24, 2014 10:01 AM
nnik
Jun 14, 2010 11:14 AM
demon_head
May 23, 2007 12:27 AM
05gtrules
May 24, 2006 02:08 PM
