Engine wont start
Old Aug 17, 2021 | 09:00 PM
BiggyBen's Avatar
BiggyBen
Default Engine wont start
Hi, I have a 2005 ford mustang gt manual 4.6l, And it wont start
It broke down about 3 days ago when driving uphill and it wont start since
I checked the inertia switch, Replaced the fuel pump, fuel filter, fuel rail pressure sensor, and the cam phasers, still no start. Last time i checked it had 15 PSI of fuel to the engine, and very rarley the car will start for about 3 seconds at 2k rpm, drop to 1000 for about 5 seconds, then stall out, I am out of ideas of what to replace or what to check, No fuel leaks or oil leaks or coolant leaks. Any help would be great
Old Aug 18, 2021 | 01:05 PM
hammeron's Avatar
hammeron
your measured fuel pressure seems low, according to workshop manual it should be at least 30 psi.
https://iihs.net/fsm/?d=312&f=SPECIFICATIONS.pdf
if you feel pressure is good to go, i would think about doing a compression test to verify no valve
or piston damage.
Arturoo Beta
Mar 10, 2018 02:08 AM
cema93
Sep 28, 2013 04:42 PM
Shredder505
Mar 22, 2012 09:05 AM
g9m3c
Oct 22, 2010 06:51 AM
philly3384
Apr 11, 2005 11:22 PM
