A/C
Old Jan 15, 2024 | 12:24 PM
rocky321's Avatar
rocky321
Default A/C
2008 GT. Literally over night the A/C went from blowing cold to blowing warm. Clutch is spinning. There was a torrential downpour, and I discovered the front passenger carpet soaked and have no idea where the rain came in. Since the computer is in the kick panel on that side I was thinking related??
Old Jan 15, 2024 | 05:32 PM
Derf00's Avatar
Derf00
Gentleman's Relish
There is no computer in the kick panel but there is the Smart Junction Box which has been known to get leaks around it.
Take a picture of the SJB with the cover off of it for fuse and relay placement, disconnect the negative battery terminal, then remove all the fuses and relays of the box and check for water in and around the box.
f you spot any, It's probably best to remove the kick panel itself to get easier access and be able to more thoroughly dry it. You'll need to loosen the trim along the bottom of the door opening and loosen the moulding/trim around the door opening near the dash to remove it.
Old Jan 15, 2024 | 06:23 PM
rocky321's Avatar
rocky321
Great info. Do you know where the water is getting in from?
Old Jan 16, 2024 | 01:41 AM
Dino Dino Bambino's Avatar
Dino Dino Bambino
Almost certainly through the cabin air filter because the cowl drains are blocked and the cowl is full of water.
Old Jan 16, 2024 | 09:36 AM
rocky321's Avatar
rocky321
Thanks!
Old Jan 16, 2024 | 11:50 AM
rocky321's Avatar
rocky321
Spot on correct! The rubber drain funnels were completely impacted with debris. Since I'm in Florida with torrential down pours, I just removed them completely! There is a water line almost halfway up the cabin air filter. No wonder the carpet is wet!
2007StangV6
Feb 26, 2015 08:39 PM
Topless06
Mar 29, 2009 01:08 PM
kpotier
Apr 16, 2007 11:02 AM
Black95Fiveoh
Jul 30, 2006 05:07 PM
so1o2k3
Jun 28, 2006 10:08 PM
