Fail Safe Engine mode difficulties
Old Oct 30, 2025 | 04:13 PM
S197Brooks's Avatar
S197Brooks
Default Fail Safe Engine mode difficulties
my 2005 GT, when cranking the the key two times (engine off) will show “Fail Safe Engine Mode” and has a weird start up and typically shuts the car off by itself, i then cleaned the throttle body and the flaps, and cleaned the maf sensor. problem still sorta occurred but less frequent than usual. the last 2 weeks its been completely fine and feeling great again, but this morning it went into fail safe mode with the engine off and then i cranked it and the start up put the rpms way to high 1400-1500 and then immediately drops to 850-950rpms, and it just sounded weird too obviously. im very curious as to what route i should take, and i don't want to just change the throttle body and then it be the PCM causing this. if you know anything about this problem please reach out to me. Thank you!
Robert Delmore
Dec 22, 2016 02:18 PM
godfather_go3
Apr 29, 2011 08:58 PM
pxdig
Apr 24, 2009 11:25 AM
ndamus88
Aug 13, 2006 08:00 PM
dobry
Jul 27, 2005 12:44 PM
