4 Cylinder NA and Turbo This section is for questions pertaining to stock or modified 4 cylinders, including the performance 2.3L applications
mustang stock block turbo oil feed
Old Aug 2, 2007 | 07:24 PM
mg man 75's Avatar
mg man 75
Default RE: mustang stock block turbo oil feed
Turbocoupe coolant system line diagram. http://www.turbotbird.com/faqpage/cooling1.jpg
Old Aug 2, 2007 | 08:10 PM
maniac_3_2000's Avatar
maniac_3_2000
that stock oil cooler, is so ghetto lol
Old Aug 2, 2007 | 08:24 PM
sleeper_inc's Avatar
sleeper_inc
ORIGINAL: maniac_3_2000
But it works
Old Aug 3, 2007 | 03:13 PM
maniac_3_2000
if you can sleeper could you take a picture of the oil feed line were it T's with the oil pressure sensor?
Old Aug 3, 2007 | 04:24 PM
sleeper_inc
Sure. Here is the picture. You see it just screws in at a tapped hole on the bottom of the sender
Old Aug 3, 2007 | 04:34 PM
mg man 75's Avatar
mg man 75
Highly recommend replace the steel the line has tendency to leak at fittings and crack in line. There is a site how to build one using AN fittings and stock brass fitting. Did it works real good.
Old Aug 3, 2007 | 06:55 PM
sleeper_inc
I'll see if my local parts shop has the steel bradded line that I need. or I'll just use teflon[:-]
yurizx6r
Sep 7, 2015 06:40 PM
Urambo Tauro
Sep 7, 2015 12:47 PM
Soldier GT
Aug 12, 2015 03:46 PM
daytooday
Aug 11, 2015 09:22 AM
yurizx6r
Aug 11, 2015 07:50 AM
