4 Cylinder NA and Turbo This section is for questions pertaining to stock or modified 4 cylinders, including the performance 2.3L applications
Headlight problem
Old Feb 5, 2008 | 04:13 PM
mustangmonster's Avatar
mustangmonster
Default Headlight problem
Ok first off i have a 1992. Thing is when i turn on my running lights the left blinker works. Then when i turn on my brights the driver side headlight is slightly dimmer than the passenger side and then try the left blinker, the whole driver side headlight dims all the way to practically nothing. When i turn on my bright brights the whole left headlight dims the same way. passenger side works fine all the way around and i have no clue as to why this is...
[align=left] [/align]
Old Feb 5, 2008 | 04:47 PM
924banger's Avatar
924banger
Default RE: Headlight problem
Sounds like you have a short.
Are any of the bulbs shot? I know when I took my pass blinker bulb out to replace itnone of the blinkers would work until I put a bulb back in.
Old Feb 5, 2008 | 06:29 PM
hockey's Avatar
hockey
when wierd things like that happen ,it could be a ground problem!!!
they are several ground points on the radiator support check them out .
make sure they are grounded good!
make sure all the bulbs are good.
Old Feb 5, 2008 | 07:52 PM
mbudden's Avatar
mbudden
you might have a bad switch. in auto tech a coustomer had a bad switch in a taurus go out and had some what same problems, replaced it and it had no problems.
Old Feb 5, 2008 | 08:17 PM
mg man 75's Avatar
mg man 75
Second with hockey. Sounds like ground problem. Wire broken connection or bad connection. I would remove one at time ground wire and clean parts wire part and body. Even if looks good will probably find problem.
Old Feb 8, 2008 | 05:35 AM
mustangmonster
alright thanx guys... havent been able to check that out yet but i will. crazy thing is they worked for like 10 minutes yesterday and then it went back to the way it was... im sure it is the grounding issue.
StalkerGT
Nov 28, 2015 03:09 PM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
ccdguy
Sep 19, 2015 05:20 PM
Mobiusone stang
Sep 7, 2015 08:46 PM
amandahchase
Sep 3, 2015 10:09 AM
