4 Cylinder NA and Turbo This section is for questions pertaining to stock or modified 4 cylinders, including the performance 2.3L applications
boost gauge HELP
Old Apr 15, 2008 | 09:01 AM
foxbody_89's Avatar
foxbody_89
Default boost gauge HELP
anybody wanna tell me the easiest way to hook up my boost gauge. i jus got a fuze gauge from sunpro and imnot exactly sure how to install it. any help would be appreciated guys thanks.
Old Apr 15, 2008 | 12:42 PM
92lxsleeper's Avatar
92lxsleeper
Default RE: boost gauge HELP
hook it right to your vaccuum tree (easiest)
or u could do it right and tap it into your intake manifold.
Old Apr 15, 2008 | 01:41 PM
foxbody_89's Avatar
foxbody_89
well the instructions say there should be a hole already that i can jus screw in an adapter to do it but im not exactly sure where.
and would i need to hook into the upper or lower intake?? or does it matter
Old Apr 15, 2008 | 02:42 PM
92lxsleeper
it doesn't matter becuase it measures the manifold absolute pressure. you can hook it off the vacuum tree. thats how i had it on my 2.3
u need to go to autozone and get a fitting.. its plastic and looks like a T. if goes into a vacumm line to make an additional one. next you have to get a rubber fitting that goes onto your hard line (comes with the gauge) to allow it so slip onto the T. or just a piece of 1/8" ID fuel line (moped fuel line or weedeater).
Old Apr 15, 2008 | 05:22 PM
foxbody_89's Avatar
foxbody_89
alright i was looking at the lower intake and remembered that i leave the knock sensor so i took it out and my fittting was the right size. would that be a good spot tohook it up to??
Old Apr 15, 2008 | 05:32 PM
sleeper_inc's Avatar
sleeper_inc
The knock sensor is not a through hole.
Just connect it to the vacuum tree than you don't have to drill and top holes
Old Apr 15, 2008 | 05:37 PM
foxbody_89's Avatar
foxbody_89
ok well which one do i connect it to on the tree?
Old Apr 15, 2008 | 06:06 PM
92lxsleeper
ORIGINAL: foxbody_89
anyone, just put a T splitter on it like i told you earlier.
Old Apr 15, 2008 | 06:31 PM
sleeper_inc
Any one will work, jet one with a cap since your not taking vacuum/boost away from anything then, delaying their reaction
jwog666
Dec 27, 2021 08:09 PM
Galactic
Apr 29, 2019 02:56 PM
andrew1969
16
Jan 8, 2016 02:48 PM
TCStangerv6
Oct 11, 2015 05:57 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
