4 Cylinder NA and Turbo This section is for questions pertaining to stock or modified 4 cylinders, including the performance 2.3L applications
'92 acceleration problem
Old Jun 10, 2010 | 08:31 AM
Elcameeeno's Avatar
Elcameeeno
Default '92 acceleration problem
So, my kids '92 'vert was running fine, then last night while driving it instantly lost power and won't pull enough RPM to run more than about 25 MPH. With the car in the driveway in park, if I manually open the throttle all the way it labors up about an additional 1000 rpm and just hangs there. Its not throwing any engine codes either. It just won't spin up. Any ideas on where to start? Ignition control module maybe?
Old Jun 10, 2010 | 12:18 PM
Babybudistmonk's Avatar
Babybudistmonk
I would say the ignition is probably ok. I would clean the mass air flow to start. CRC makes a good cleaner to spray it down with. See if that helps. I would also check the TPS and make sure that is functioning properly.
Old Jun 10, 2010 | 08:13 PM
Elcameeeno's Avatar
Elcameeeno
Well, I measured the TPS and had .9v at idle and 2.2v at WOT. So I figure its bad, right? I replace it and the new one gives me the same reading. WTF? Shouldn't it be about 3.6v at WOT? Is it possible to short one out? I did the pins through the wiring deal and they did short. Will that hurt it? I am at a loss.
MAF was replaced a year ago.
Ideas?
Old Sep 15, 2020 | 10:49 PM
nickstick17's Avatar
nickstick17
[Please delete this reply - somehow ended up in the wrong thread]
Old Sep 19, 2020 | 03:21 PM
imp's Avatar
imp
What engine, and is it original 1992, EEC-IV EFI system, NOT EEC-V? If '92 original,
check fuel pressure at Schrader Valve. if low, go to fuel supply system: filter and pump output. Sudden clogging of fuel filter has been known to happen and will cause exactly your problem. If supply system OK,
go to fuel pressure regulator on engine fuel rail. If it's bypassing most of the supplied fuel, injectors get too little. Regulator easy to replace.
Mike T
Dec 23, 2012 03:37 PM
Unsullied_Spy
15
Jun 19, 2009 01:08 AM
haromaster87
Nov 11, 2008 10:53 PM
89TripleWhite
Dec 11, 2007 11:57 AM
jthorn9
Jul 16, 2007 10:10 PM
